  • Replies 814
I think, there should be examples in this topic, which needs to slightly modify.
Why do You think, that hubs wont be good for trial truck? for live axle?
I don't think that hubs won't work, sorry. I meant that I have a limited supply of them (not enough to make 4 axles).
Ok, then it's clear.
If You don't use hubs, there is possibility, that wheels could slip off form axles. Of course, You can fix them with some half bushes (they have some better grip). But maybe start some MOC topic, so we don't get too much in offtopic here.
Maybe even admins can spearate these posts here?
I was working on an axle for the MOC I am doing.  I am somewhat happy with it, but I figured I could post it here and maybe get some feedback.
The shocks go downward and connect to the blue pin/axle connector near the bottom.
It has the opportunity to have powered axles, but I will not be doing that.  Also, I will be trying to make the rearmost axle steerable once my bricklink order comes in.
LDD file
https://bricksafe.com/files/Aminnich/gsk55/Axle.lxf
LDD file
It looks good, but schocks are on oposite direction :laugh:
It could be used on trailers :thumbup:
... The shocks go downward and connect to the blue pin/axle connector near the bottom.
Looks like an interesting setup, but there is one point I don't understand: why are you using the ball joints as a hinge for each axle? The shocks are mounted with pins directly to the chassis and the axle, as a result they can only move in one plane. This means that they will be forced to bend when your axles twist.
You could either change the hinge points to a simple pin connection, making it less complex but then you will loose the ability of twisting the axle. The alternative is to mount the shocks more flexible so they can move in two directions. Take a look at how the shocks in the Arocs are mounted as an example.
Good luck!
Edited by Cumulonimbus
I'm currently working on mid scale Tatra and I need an advice. This is front axle:
37726153875_482e00f77c_c.jpgTatra front axle by Ivan Moc
but I don't know where to put springs. Ideally they would be on top of the pivot point of the wheel but the scale doesn't allow that. Any ideas? Thank you
@Ivan_M IMHO @Zero (Zblj) made best small scale Tatra axle, so it would be wise to contact him to send you a link for his tread (because I could not find it fast enough)
I think this is correct tread
Edited by I_Igor
Yes i know his builds, my axle is based on it. The problem is I'm not building trial truck and I'm working with 49,5mm wheels so the space is limited. I think I will try to make some push rod setup
I see. I personally am not a fan of Tatra axles, so I stick to Unimog axles...
Replace nofrictionless pin with 3L pin (blue one). Friction increase wont be critical. Maybe frictionless 3L pin would be also ok.
Then put on it part
and with 2l (mostly red) axle connect shock absorber.
You could try to build steering with 9L links, then steering wont be so much affected by suspension travel.
O, just realised, that there is 1.5L pin ... :cry_sad:
Edited by Jurss
If available space is an issue, you might need to use one shock absorber, lay horizontal and us it to link the left and right halves of you suspension. I don't have the tools here to visualise my idea, but I think you can figure it out.
It's probably not accurate to the real deal, but does the trick.
U can use axles as spirngs
Put some axle/axle or axle/pin connector (that thing in red) on the suspension arm, put some axle trough (blue), and connect its other end (red cross) as far as possible. For other side it will be harder to implement.
Or You can try to use this rubber thing somehow
Edited by Jurss
What about using torsion bars?, in the case that your model wont have a drive train, you could attach the half axles directly to the cross axle and the pivoting movement would be "suspended", or place those rubber parts above each half axle.
No it is not, I don't like axles with pivot point too far from wheel center. This axle is for truck 15L wide so driven and steered axle would be too big. I have put this on hold for a while but I can finish the digital file with rear axles and put it here
