Zerobricks Posted December 2, 2017 Posted December 2, 2017 You can make this driven with minimum modifications Quote
Ivan_M Posted December 2, 2017 Posted December 2, 2017 Yes I guess so, but it would require moving pivot point one stud to the centre. That would mean wider fenders. I realized that such model is working much better as motorized one and I really don't enjoy remote models as much as manual ones. That is why I abandoned it for now. I have to admit though that the performance with one L motor is amazing and the suspension is working like charm (on rear axles). Quote
Zerobricks Posted December 3, 2017 Posted December 3, 2017 13 hours ago, Ivan_M said: Yes I guess so, but it would require moving pivot point one stud to the centre. That would mean wider fenders. I realized that such model is working much better as motorized one and I really don't enjoy remote models as much as manual ones. That is why I abandoned it for now. I have to admit though that the performance with one L motor is amazing and the suspension is working like charm (on rear axles). Or you can us CV joints which require no movement of pivot pints. Quote
HorcikDesigns Posted December 3, 2017 Posted December 3, 2017 10 hours ago, Zero (Zblj) said: Or you can us CV joints which require no movement of pivot pints. But there is no room for gears in the frame. and also in the half-axle. (judging only from photo) Quote
1gor Posted December 3, 2017 Posted December 3, 2017 22 minutes ago, HorcikDesigns said: But there is no room for gears in the frame. and also in the half-axle. (judging only from photo) Take a look on page 13 Tatras have bevel gears on drive axles so it could fit inside Quote
Ivan_M Posted December 3, 2017 Posted December 3, 2017 10 hours ago, Zero (Zblj) said: Or you can us CV joints which require no movement of pivot pints. But that build was with 30,4mm wheels and 49,5mm tires. There is one wheel in that size with 3 pinholes for wheel hub, but I don't have them. Maybe I will try that when I return to this build Quote
Imanol BB Posted December 3, 2017 Posted December 3, 2017 As i can see, you can easily achieve drive in the axle by using CV joints, it wont affect the turning pivot, but the only problem would be to stack gears in the 7x5 frame, as it would require to move the half axles pivot point 1 stud up, which would affect the clearance a lot, but for me, that scale is perfect for a driveless suspended vehicle, specially a Tatra. Quote
Superkoala Posted December 4, 2017 Posted December 4, 2017 On 10/11/2017 at 8:55 PM, aminnich said: @aminnich a question about your system: do you think it can be motorized ? I have some idea to make a suspended triple-axle truck and I'm still not sure of how I must/will build it. I like your idea and i may upgrade it so it will fit my specs. Quote
HorcikDesigns Posted December 4, 2017 Posted December 4, 2017 (edited) 16 hours ago, I_Igor said: Take a look on page 13 Tatras have bevel gears on drive axles so it could fit inside No, it will not fit inside. I know very well, how Ledwinka's solution in Tatra style suspension (swinging half-axles) work. I have also tried to build this type of suspension for my tril trucks many times, so you can trust me, that this assembly can not fit CV- or U-joints and gearing at the same time. Firstly, any LEGO bevel gears on the main driveshaft (that is going through Tatra's "spine") would collide with the frame (5x7 technic beam), and secondly, this axle is too narrow to fit complete assembly of original joint, bearing and smallest bevel gear next o each other. An internal structure, that is shown on previous site, does not allow mounting any gears that would mesh with it's counterpart. Any modiications that would lead to making this axle driven would make entirely new one. Maybe am I wrong, but please prove it with picture of minimally modified previous axle. Edited December 4, 2017 by HorcikDesigns Quote
aminnich Posted December 4, 2017 Posted December 4, 2017 (edited) 5 hours ago, Superkoala said: @aminnich a question about your system: do you think it can be motorized ? I have some idea to make a suspended triple-axle truck and I'm still not sure of how I must/will build it. I like your idea and i may upgrade it so it will fit my specs. Of course it could be. Each axle would be independently driven. If you want the file, I could send it to you Edited December 4, 2017 by aminnich Quote
Superkoala Posted December 4, 2017 Posted December 4, 2017 11 minutes ago, aminnich said: Of course it could be. Each axle would be independently driven. If you want the file, I could send it to you Thank you for your answer. I have another project to complete before working on a new truck, so I will try to built it from my own and i mail you later if I need to use your file as help. Quote
1gor Posted December 4, 2017 Posted December 4, 2017 2 hours ago, HorcikDesigns said: No, it will not fit inside. I know very well, how Ledwinka's solution in Tatra style suspension (swinging half-axles) work. I have also tried to build this type of suspension for my tril trucks many times, so you can trust me, that this assembly can not fit CV- or U-joints and gearing at the same time. Firstly, any LEGO bevel gears on the main driveshaft (that is going through Tatra's "spine") would collide with the frame (5x7 technic beam), and secondly, this axle is too narrow to fit complete assembly of original joint, bearing and smallest bevel gear next o each other. An internal structure, that is shown on previous site, does not allow mounting any gears that would mesh with it's counterpart. Any modiications that would lead to making this axle driven would make entirely new one. Maybe am I wrong, but please prove it with picture of minimally modified previous axle. I agree that without modifications you can not make driven axle...I'll see if I found time to build it, but I does not guranty enything because every builder can make something better that other Quote
aminnich Posted December 4, 2017 Posted December 4, 2017 I never planned on powering that axle, that is why I designed it the way I did. The only reason I used the Ball Joint Large Open with C-Shape Pivot Frame was for another pivot point with a solid base. It probably could have been done a little bit differently without that part, but I thought this worked well for my application. To power this axle, I feel like a bunch of modifications would have to be made, BUT it could be powered. Quote
Zerobricks Posted December 4, 2017 Posted December 4, 2017 Just now, aminnich said: I never planned on powering that axle, that is why I designed it the way I did. The only reason I used the Ball Joint Large Open with C-Shape Pivot Frame was for another pivot point with a solid base. It probably could have been done a little bit differently without that part, but I thought this worked well for my application. To power this axle, I feel like a bunch of modifications would have to be made, BUT it could be powered. I already made a powered version with CV joints, 12 tooth bewel gears and different wheels in the same width. I will share photos soon. Quote
Zerobricks Posted December 4, 2017 Posted December 4, 2017 As promised here is the photo of the idea: I am tempted to build a small tatra whit this setup Quote
aminnich Posted December 4, 2017 Posted December 4, 2017 How would that work with the axle I have posted above?? Looks completely different to me. Quote
Ivan_M Posted December 4, 2017 Posted December 4, 2017 2 hours ago, Zero (Zblj) said: As promised here is the photo of the idea: I am tempted to build a small tatra whit this setup Interesting, but you have 1 stud offset between the wheels and that is too much for this scale Quote
HorcikDesigns Posted December 4, 2017 Posted December 4, 2017 (edited) 49 minutes ago, Ivan_M said: Interesting, but you have 1 stud offset between the wheels and that is too much for this scale I would like to apologise, I forgot this part (small U-cage, or bevel gear bracing), it is possible to palce the gears and joint into your axle, although the offset is too big, and the 5×7 frame can not be used, and the structure would not be very rigid. Edited December 4, 2017 by HorcikDesigns Quote
1gor Posted December 5, 2017 Posted December 5, 2017 9 hours ago, HorcikDesigns said: I would like to apologise, I forgot this part (small U-cage, or bevel gear bracing), it is possible to palce the gears and joint into your axle, although the offset is too big, and the 5×7 frame can not be used, and the structure would not be very rigid. All good my friend 10 hours ago, Ivan_M said: Interesting, but you have 1 stud offset between the wheels and that is too much for this scale I do not know if this info is usefull, but with 49.5 tires whole axle is some 6mm narrower which is about 1 stud Quote
Ivan_M Posted December 5, 2017 Posted December 5, 2017 (edited) 33 minutes ago, I_Igor said: I do not know if this info is usefull, but with 49.5 tires whole axle is some 6mm narrower which is about 1 stud I don't understand what do you mean, I'm talking about this: the offset between left and right wheel is 1 stud and that is too much in smaller scale, the whole steering acts funny with it. I don't like half stud offset on steered axle as well (in this scale), it just brings too many problems. That is why I decided for non-driven steered axle with zero offset. Not really following the source material, I know, but I'm fine with it. Edited December 5, 2017 by Ivan_M Quote
Jurss Posted December 5, 2017 Posted December 5, 2017 And that thing will pop out under the load Quote
1gor Posted December 5, 2017 Posted December 5, 2017 3 hours ago, Ivan_M said: I don't understand what do you mean, I'm talking about this: the offset between left and right wheel is 1 stud and that is too much in smaller scale, the whole steering acts funny with it. I don't like half stud offset on steered axle as well (in this scale), it just brings too many problems. That is why I decided for non-driven steered axle with zero offset. Not really following the source material, I know, but I'm fine with it. I know what are you talking, but the bottom line is vehicle width. 49.5 X 20 wheels are more narrow than 56 x 26 that are on image. Every Tatra has actually some offset Quote
Jurss Posted December 5, 2017 Posted December 5, 2017 Half stud offset https://bricksafe.com/files/Jurss/visskas/hst_tatra.lxf but just LDD, maybe that one side would bend in real model. Quote
Zerobricks Posted December 5, 2017 Posted December 5, 2017 Here's an upgrade of @Jurss 's design with a higher gear ratio and a stiffer gearbox: Quote
