Ti-Max Posted December 22, 2017 Posted December 22, 2017 Here is a double wishbone front suspension that i just made with all the fancy angle and unequal length a arm with a soft and long travel. Its scaled for the 81.6 tyres. Quote
1gor Posted December 22, 2017 Posted December 22, 2017 Just to mention, about 14 years ago I've made very similar solution but with suspension arms from 8466 set and upper part usually popped out when wehicle was heavier (as LEGO Unimog or even more...) Quote
Jurss Posted December 28, 2017 Posted December 28, 2017 Some rear independent axle ~25L with 56 wheels (some 2 studs narrower than with traditional hubs) Could be made to some 24L wide, if swingarms would be attached 6 studs from each other, not 7 as by this design. Travel is very limited, just some stud, maybe little bit more. On the left side there is "limiter" added (that 3L liftarm under shock absorber) Quote
suffocation Posted December 29, 2017 Posted December 29, 2017 Heavy-duty live axle. Features: - mounted servo- planetary reduction (1:4, 1:5.6 including diff) - positive caster - torque tube - Panhard rod Quote
Ivan_M Posted December 31, 2017 Posted December 31, 2017 I need help from you skilled guys regarding steering system on 4 axle truck, where first two live axles are steered suspended but not driven. The two axles are quite far from each other, around 20 studs. It will be manual. I have working concept with link steering where both link levers are connected by axle with gears, but I don't want to spend hours implementing it to get to point where it shows as rubbish. So my question is - would you connect such axles with linkage system like I have, or linkage system without gears or rack? Linked steering idea vertical axle is hog, reduction to first axle is 12:20, to second 1:3 to get reduced steering angle Thanks! Quote
suffocation Posted January 1, 2018 Posted January 1, 2018 I tried something similar a while back - too much slack for my taste. I think Zerobricks figured out a more effective way: Quote
grego18f Posted January 7, 2018 Posted January 7, 2018 (edited) I came up with this simple design for a rear tandem: Edited January 7, 2018 by grego18f Correct link to pictures Quote
aminnich Posted January 7, 2018 Posted January 7, 2018 1 hour ago, grego18f said: I came up with this simple design for a rear tandem: Just a heads up, we cannot see the pictures Quote
Technivor Posted January 7, 2018 Posted January 7, 2018 2 hours ago, grego18f said: I came up with this simple design for a rear tandem: Spoiler If you plan to use it on a heavy motorized truck I'm affraid to tell you that the 12t gear will slip! I know that because it is the design I've used for the past year and mine was reinforced from either side of the gear. Quote
grego18f Posted January 7, 2018 Posted January 7, 2018 7 hours ago, Technivor said: If you plan to use it on a heavy motorized truck I'm affraid to tell you that the 12t gear will slip! I know that because it is the design I've used for the past year and mine was reinforced from either side of the gear. Can you share how you managed to secure the 12t gear? Quote
Technivor Posted January 7, 2018 Posted January 7, 2018 15 minutes ago, grego18f said: Can you share how you managed to secure the 12t gear? I didn't, I just decided to put the U-joint at the front of the frame and use a gear that didn't have much friction (8t red, new 16t or 20t) between the motors. Quote
grego18f Posted January 8, 2018 Posted January 8, 2018 (edited) 12 hours ago, Aventador2004 said: Is it for the mack Granite? I am affraid it is not As already mentioned by @Technivor, it is not strong enough for high torque... Before going for Mack, i was working on a RC Volvo FH16 6x4. The frame worked like a charm. The rear tandem is from Efferman. Feel free to use it! Note: The front hubs a those from the 8070 supercar. And the lxf Edited January 8, 2018 by grego18f Quote
Beck Posted January 8, 2018 Posted January 8, 2018 @grego18f I have experimented with tandems for almost 2 years now and have found a simple fix for the slipping even under the greatest stress. Use part 42003 on either side of the 5x7 frame (with 2l pins)and connect the technic axle holes with axles and 7l beams. The 12 tooth gear should sit inbetween the two beams. There’s an lxf for download if you’d like here: https://bricksafe.com/pages/Beck/technic_mocs/8x4-chassis-pf-1.16-scale Quote
RickSanchez Posted January 16, 2018 Posted January 16, 2018 hey guys new here, this is my first custom build in a while. i intend to build a 6x6 frame to be used for various military and heavy duty trucks. starting simple, this is custom 13 wide driven steerable pendular front end for the Arocs frame. Quote
1gor Posted January 16, 2018 Posted January 16, 2018 (edited) 9 hours ago, RickSanchez said: hey guys new here, this is my first custom build in a while. i intend to build a 6x6 frame to be used for various military and heavy duty trucks. starting simple, this is custom 13 wide driven steerable pendular front end for the Arocs frame. not bas - it can be used for some Arocs 6 x 6 model, but how does it look if you invert wheels because this way it is very wide Welcome to Eurobricks Edited January 16, 2018 by I_Igor Quote
Zerobricks Posted January 30, 2018 Posted January 30, 2018 Here is an idea for axles only a stud wider than the ones used in Arocs, which include differentials with a high gear ratio (over 1:2) to reduce the strain on the U joints and reduce the torque twist: Download LXF here: https://bricksafe.com/files/Zblj/Misc/Medium axle high gear ratio diff.lxf Quote
TheNextLegoDesinger Posted January 30, 2018 Posted January 30, 2018 very interesting, clever way to use those studded frames Quote
Victor Imaginator Posted February 4, 2018 Posted February 4, 2018 (edited) Just built some steered non-driven suspension using 42000 arms and new pinhole-axle LBG connectors. With 3.5-4 studs travel it looks better with larger wheels. But with soft shocks it can be used only for very lightweight models. Can't test it with hard shocks, because don't have it yet( But hard shocks may require additional bracing. Construction allow to use some longitudinal bracing inside, if it's necessary. Also - here's maximum possible steering lock using 7L rack. Edited February 4, 2018 by Victor Imaginator Quote
Zerobricks Posted February 17, 2018 Posted February 17, 2018 (edited) Here's an idea inspired by the axle from G63 AMG 6x6: As you can see the axle uses brick built hubs with a combiantion of the ball joints. This setup moves the virtual steering pivot point well inside the tyre: The advantages of this setup are as following: Lower force needed to steer the wheels Reduced sensitivity to bumps The wheels naturally self-center No need for massive wheel arches More realistic And of course there are a few disadvantages: More complex than normal solution Needs more space needed More moving parts Because the hubs are brick built, they may not be as sturdy Edited February 17, 2018 by Zerobricks Quote
LithuanianLegoFan Posted February 18, 2018 Posted February 18, 2018 HERE IS WORKING PROTOTIPE OF STRONG INDEPENDENT SUSPENSION WITH DRIVE Quote
Saberwing40k Posted February 19, 2018 Posted February 19, 2018 This is a creation of @barman. We first saw it in this thread, Now, I'm willing to give you the benefit of the doubt, and assume you are just posting this because you found it, and want to share it, in which case it would be nice to include credit and link back to the original creator. We as a community frown upon theft of ideas and photos, but I'd rather give you a fair warning, as you seem to be new around these parts. Quote
letsbuild Posted February 19, 2018 Posted February 19, 2018 6 hours ago, LithuanianLegoFan said: HERE IS WORKING PROTOTIPE OF STRONG INDEPENDENT SUSPENSION WITH DRIVE 3 hours ago, Saberwing40k said: This is a creation of @barman. We first saw it in this thread, Also, it isn't very nice to use all caps when writing on this forum. Quote
LithuanianLegoFan Posted February 19, 2018 Posted February 19, 2018 11 hours ago, Saberwing40k said: This is a creation of @barman. We first saw it in this thread, Now, I'm willing to give you the benefit of the doubt, and assume you are just posting this because you found it, and want to share it, in which case it would be nice to include credit and link back to the original creator. We as a community frown upon theft of ideas and photos, but I'd rather give you a fair warning, as you seem to be new around these parts. I am very sorry Quote
Saberwing40k Posted February 19, 2018 Posted February 19, 2018 It's okay. Everybody goes through a noob phase on this site. You'll learn from this and be a better person for it. Also, another tip, don't quote big blocks of text like you did. Quotes are more of an art than a science, but in general less is more. Quote
