efferman Posted July 7, 2019 Author Posted July 7, 2019 Could you please share the lxf so we can test it? Quote
dobob Posted July 7, 2019 Posted July 7, 2019 47 minutes ago, efferman said: Could you please share the lxf so we can test it? i added a link to my dropbox Quote
efferman Posted July 8, 2019 Author Posted July 8, 2019 Thank you. Had take a look on it and i have doubts about the torque to handle. Quote
dobob Posted July 20, 2019 Posted July 20, 2019 Thanks for your feedback. I build it... I think it handles the torque since the model will be very small. The main problem I did not think about is, that steering the wheels also turns them. This effect is way worse than having no differential. So I doubt that my idea to have separate motors for the left and the right side of the vehicle is the best. Quote
efferman Posted August 20, 2019 Author Posted August 20, 2019 Axle for 19 wide, Ackermann steering, planetary hubs https://bricksafe.com/files/efferman/vehicle-axles/19 wide planet axle steered.io Quote
Mechbuilds Posted August 23, 2019 Posted August 23, 2019 Here's another great axle from @efferman. He designed it for my need. -13 studs from tyre to tyre. -Non driven -2.5 studs of ground clearance. -Good steering angle. -Durable Quote
efferman Posted August 24, 2019 Author Posted August 24, 2019 The Files for the axle above : LXF / .io Quote
Mechbuilds Posted August 26, 2019 Posted August 26, 2019 (edited) Does anybody have any tips on an 13 stud wide rear axle? This is what i came up with: Very heavy duty and motor on axle. Always locked so no diff. The speed and torque can be modified by changing the gearing on the portal hubs. It's a crude design but compact i guess. It's hard to figure out a suspension for this axle though. And how to attach the XL motor so it won't just fall off. Does anybody have any 13 stud wide designs (from tire to tire.) (i guess it's technically 19 studs if you count the tire width.) What i need is an axle + suspension so i know how to attach it. I can also mount the motor to the body too. (i'm using the front axle that @efferman posted.) Edited August 26, 2019 by Mechbuilds Quote
Zerobricks Posted August 26, 2019 Posted August 26, 2019 1 hour ago, Mechbuilds said: Does anybody have any tips on an 13 stud wide rear axle? This is what i came up with: Very heavy duty and motor on axle. Always locked so no diff. The speed and torque can be modified by changing the gearing on the portal hubs. It's a crude design but compact i guess. It's hard to figure out a suspension for this axle though. And how to attach the XL motor so it won't just fall off. Does anybody have any 13 stud wide designs (from tire to tire.) (i guess it's technically 19 studs if you count the tire width.) What i need is an axle + suspension so i know how to attach it. I can also mount the motor to the body too. (i'm using the front axle that @efferman posted.) Just use a 5x7 frame like 42030 does. Quote
Runeman Posted August 27, 2019 Posted August 27, 2019 I am really not very good at this, but how does that rear axle work? To me it looks like the two wheels would rotate in opposite directions. Quote
keymaker Posted August 27, 2019 Posted August 27, 2019 53 minutes ago, Runeman said: I am really not very good at this, but how does that rear axle work? To me it looks like the two wheels would rotate in opposite directions. No no, the gray gear is a "dummy" gear. It is there only for support and look ;) Quote
Runeman Posted August 27, 2019 Posted August 27, 2019 Thanks. A pinhole gear, that makes sense also looking at the colours, I am really a novice . Quote
Mechbuilds Posted August 27, 2019 Posted August 27, 2019 (edited) 21 hours ago, Zerobricks said: Just use a 5x7 frame like 42030 does. Well a swinging rear axle could work. But i was thinking more of that the rear axle + xl motor would be hanging from springs and those ball cup arms so it would also have up and down play and sideways swing. Edited August 27, 2019 by Mechbuilds Quote
suffocation Posted September 1, 2019 Posted September 1, 2019 (edited) Has anyone managed to come up with anything heavy-duty (e.g. live axle with mounted servo; driven and steered independent suspension with three or more springs) using the new planetary hubs? I got a set of them and I'm finding them very frustrating to implement, but it could be due to ramping senility. Edited September 1, 2019 by suffocation Quote
Zerobricks Posted September 1, 2019 Posted September 1, 2019 (edited) 2 hours ago, suffocation said: Has anyone managed to come up with anything heavy-duty (e.g. live axle with mounted servo; driven and steered independent suspension with three or more springs) using the new planetary hubs? I got a set of them and I'm finding them very frustrating to implement, but it could be due to ramping senility. Yes, check here: I will start working on LDD file and video soon. Edited September 1, 2019 by Zerobricks Quote
suffocation Posted September 3, 2019 Posted September 3, 2019 On 9/2/2019 at 1:28 AM, Zerobricks said: Yes, check here [snip] Thank you! I tried to come up with a live axle for my rough terrain crane reboot but found it really hard to stop the arms from bending under weight: that extra pinhole they included to make Ackerman easy for noobs is a nuisance. Anyway, this is what I came up with: hopefully some of the countless builders far more skilled than me will improve on it. (This version has no Ackermann as the crane I designed it for is going to have crab steering). Quote
suffocation Posted September 9, 2019 Posted September 9, 2019 A much more robust version of the axle posted above: Quote
Mechbuilds Posted September 11, 2019 Posted September 11, 2019 Here is a heavy duty axle i designed for my truck project. It can handle the massive torque of the XL motor paired with buwizz ludicrous mode. And you have the option to not only move from Slow-Normal-Fast-Ludicrous modes but also gearing options from 1:1, 1,6:1 and 3:1 after the 1,6:1 reduction after the XL motor offcourse. But i need a little help with it. Where and how should i mount the springs for it so i get a suspension. Also how do i mount the ball cup socket beams so it doesn't wobble and flex. I have the LFX if anybody has any ideas? Quote
Zerobricks Posted September 11, 2019 Posted September 11, 2019 (edited) Might be a bit offtopic, but the new rims from defender allow you to create a custom hubs with a deeper steering point. Depending if you use the bearing element to securely attach the wheels to the axles or not you can gain between 1-2 studs. Edited September 11, 2019 by Zerobricks Quote
Seasider Posted September 11, 2019 Posted September 11, 2019 Hi all, can someone point me in the direction of a compact front and rear suspension both with diffs and independent ideally. Thanks in advance Quote
sirslayer Posted September 14, 2019 Posted September 14, 2019 (edited) Am I the first person to post this??? If i'm wrong I will remove this post... 13 wide independent suspension with driveshaft with steering available Head full of ideas!! Edited September 14, 2019 by sirslayer Quote
legotechnicus Posted September 15, 2019 Posted September 15, 2019 On 9/14/2019 at 10:34 AM, sirslayer said: Am I the first person to post this??? If i'm wrong I will remove this post... 13 wide independent suspension with driveshaft with steering available Head full of ideas!! That’s funny, I was thinking the same. Currently working on a project that uses a similar setup. Only need to figure out a sturdy steering system Quote
Mechbuilds Posted September 15, 2019 Posted September 15, 2019 52 minutes ago, legotechnicus said: That’s funny, I was thinking the same. Currently working on a project that uses a similar setup. Only need to figure out a sturdy steering system Like this? Quote
1gor Posted September 15, 2019 Posted September 15, 2019 @sirslayer you an make it even 2 studs more narrow using this Quote
