Thx BrianZ, but all I have are two L-motors.
Are you doing rear or front wheel drive? Rear will probably be easier - that way each axle only needs to accommodate one function.
The three simplest, common steering setups (all using rack-and-pinion steering) are
1) servo plus the 'train remote'
2) M-motor with return to center (using the 'hockey spring' or rubber bands)
3) M-motor geared down 9:1, including a clutch gear (the white 24 tooth ones) to prevent the motor from stalling
Either of the M-motor designs should work with an L-motor. Return-to-center is good for fast vehicles but limits you to steering all the way left, all the way right, or straight ahead. A geared down M-motor (or L-motor) is slower but offers more control.
Hi All
I'm not sure how to delete a topic. I thought I couldn't incorporate those two L-motors on my 8043 b-model, but I did (with a 1:1 gear ratio :sweet: it's really fast).
Thanks for all the answers.
