Ok folk, been working on this for a while now, please excuse the rubbish pics but im sure you get the ideaIve still to get a few power function parts for the base but the upper section is all working and had a lift of 2kg so far but with plans of trying for a bit moreOne thing im strugging with is, the two main winches in the body are run off the same motor and have to wind/unwind at the same speed but im strugging to get the string to wind nicely on the spool, anyone any ideas?Ok this is a 1:50th model of the real machine im working from410072_000_large_zpse6fe4dd8.jpg20140131_223140_LLS_zps2f886085.jpg63d1b579-2c40-4752-bc77-0d66371b8c7a_zpse64bb971.jpg20140131_202412_LLS_zpsfc38b187.jpg162db16d-42d3-476e-bb55-517e06be9434_zps7f43aec7.jpgc2a21006-5094-41c0-bc44-26622d5ca2cf_zps848d231f.jpg
Edited by cheeze
concerning your question about how to get your string to spool up nicely, the cranes i work around have a rod pressing down over the spooled cable so it has no choice but to roll up nice. not sure if that helps or makes any sense. nice crane though.
Cheers for the comments, Rishab, its around 1.5 meters so far ground to boom tip, but im planning on going bigger yet still, but the 5L thin liftarms are a rather pricey part.
  • 3 months later...
Ok an update to this topic, progress is slow but im at a stage i can display the model enough so here are the most recent images from today, the last image is 1.5kg hanging at 1m radius, hooks been tested to 6kg before it failed
  • 2 months later...
  • 5 months later...
Another small update on this crane, im currently building a luffing jib and have changed to a floating ballast tray
so on with some pics
The luffing arms so far
5 section main boom
floating tray
4kg of ballast
And fully equipt
Edited by cheeze
  • 7 months later...
Bit of an update
Im slowly getting to the stage of being happy with this, ive now got the lower section controlled via an s-brick for left and right track and also 2 m-motors for slewing 360.
ive done a weight test since the last update and managed 6kg with a short boom setup and 1.5kg with full boom and a section of luffing jib
So heres a few photos and a small video of crawling and slewing from an sbrick controller
1.5kg at about 1meter radius
6kg lift at closest radius possible
S-brick controlling tracks and 2x M-motors for slewing 360
  • 5 months later...
After seeing the other post re the crawler crane i had though i would update mine also.
Heres a minifig for scale on the main body
these are all the parts required for the building, i tried to make it as modular as possible for moving around
So the build begins with the rear mast being lifted
Now the boom foot is fitted
And the boom tip to rear mast
And now the full boom and Luffing arms are ready to lift, from boom tip to ballast is about 3 meters
Slow progress
But we eventually get there with it
I was never really happy with the floating ballast tray as at certain points you had to balance it just right with different weights which became troublesome and i had a few tip overs i decided to give a ballast car another go
Heres the floating tray
Looks fine and simple but the problem comes when you want to slew around, youd have to lower the boom enough so the tray would start to float, Go to far and that was it wanting to tip.
So this was the solution, both sets of wheels are powered so i can slew with the full amount of weight on it, this is powered by old 9v at the moment where as the main crane is via 2 sbricks, i may try get some PF hooked up and try that way
And a quick video of it running
