#2, in any of the lengths available (any of the part numbers starting in 5306 on BrickLink).
Note that in the 9V system, the polarity of the motor (which way it spins) depends on how you orient the connector plates at the ends of the wire where they connect with the motor and with the RC unit. If it's spinning the wrong way for what you want to do, just turn a connector 90 or 180 degrees.
