Hello everyone,
Thought I would share my quick build Tatra to test my asymmetrical half axle setup.
Turned out to be quite good surprisingly. :grin:
The body work was very quickly built, inspired more by the shape of the Tatra T813.
Specs:
20cm (H) x 20cm (W) x 38cm (L)
Weight 1.910kg
2 x XL for Drive
1x Servo for Steering
I also wanted to make it blue, and colourful just like the trial trucks. :tongue:
Edited by Doc_Brown
I take it your using a V2 Rx receiver with the twin XL motors. Have you ran into issues with the battery thermaling out or have you modded the battery box with a higher rated resistor?
Oh thanks for the great feedback guys. :thumbup:
Whats up with the stacked gear racks in the steering mechanism?
I like the blueness.
Cheers! I had to use 2 together cos the axles are offset, and thats the only way to able both wheels to turn the same radius. :sweet:
Yes I'm using V2, and no I haven't modded the thermal settings on the battery box. Generally I don't have too much of a problem with that, but with my hot rod geared 1:3 if I drove forwards backwards 3 times it would stall.
With this Tatra if a "tire" got caught in between the wheels, it would stall. :sweet:
Title is misleading...it is not just another Tatra. It is great tatra. Nice drivetrain!
Thank you very much. :grin::thumbup:
i was ironizing on what happened to the title of my topic...
once up on a time called "just another crawler"
ps: i love your signature !
Edited by astakos
HAHA, yes your thread inspired it! :grin:
Thanks, I try to apply that motif to building. :thumbup:
Very nice... Just one question: Which and whre can we find the BB?
its located between the the servo and Xls, if you look at the chassis pic, you can just see a red lever, thats the on off. Standard battery box was used. :laugh:
The blue is hot. It's always nice to see another Tatra.
How well does it turn?
Not very well!!! :tongue: If you can see how to improve it, im all ears! And thanks.
It's BLUE! That's not something that we see very often. NICE.
v/r
Andy
Thank you very much! I was unsure how much of a cab I could make with the blue that I had. :laugh:
Thanks for the nice comments and feedback guys.
Very nice design...
now time to improve it - they needs differentials on axles... ;)
I agree, with diff lock, but that is for my next Tatra! :tongue::grin:
EV3noob
You are correct.
From wich set do the Blue rims come?
I'm not too sure actually, I picked mine up from 4 diff sellers on BL, quite cheap. I just thought they look sweet! and very much like a Trial truck. hehe
