Hi
I've made a GBC ball counter which uses an android smartphone and an app I wrote in order to detect and count GBC balls.
Iv'e done this before (here), but this time I tried something different: counting the balls directly from the GBC track, without a special module.
The counter uses the phone's camera to scan a row of pixels (most of them positioned on the track itself).
If it detects a drastic change in one of the pixels' colors, it registers a pass and does some calcucations (such as balls / second).
It also waits 200ms before scanning for balls again, so the counter won't register the same ball twice.
Also included is a small algorithm that will ignore changes in lighting, to prevent false positives.
More information:
- 100% accuracy rate - never misses a ball or counts the same ball twice
- Can handle up to 5 (!) balls per second, which is 5 times more than the GBC standard
- The app uses the camera preview mode (~20 fps)
- Coded in Java for android devices.
I hope you'll like it :)
Edited by LegoGBC
I for one would like to see the source code, the image analysis is relay neat
Heres a small part of it
private boolean MeasureColors(Bitmap bitmap) {
int x = bitmap.getHeight() - 1;
for (int i = 0; i < x - 1; i++)
  if (Color.red(bitmap.getPixel(500, i)) - 60 > prevR)
     return true;
return false;
(prevR is the red channel of a pixel on the black background)
Theres a lot more, tough. This is just the method which measures the colors and returns true/false if theres a significant change in one of the pixels.
There are also methods which convert the received byte[] data to a usable bitmap (you need to first convert from YUV image to jpeg, write the jpeg to a byte array stream and read from it later on with a regular bitmap) , check for light change, calcucate BPS, handle the 200ms break after each ball etc...
Edited by LegoGBC
  • 1 year later...
