Posted April 18, 201410 yr Hi everyone. I have a question on lego 12v Remote Controlled Road Crossing and 9v system. Can this set work in 9v system if I have 12v controller? Thanks.
April 18, 201410 yr What do you mean 'can it work in 9V system'? You can put 9V track instead of 12V track. The motors will probably run on 9V but the connectors won't fit. If you have the 12V train controller then you can use that to supply power to the level crossing motors and use the 9V controller for your trains.
April 18, 201410 yr Author Thanks for your kind reply. And sorry for the poor explanation. I was going to put 9v tracks instead of 12v tracks. So, what I understand is that 9v trains get powrs from 9v controllers and leve cossing motors get power from 12v train controller right? thanks again.
April 18, 201410 yr Thanks for your kind reply. And sorry for the poor explanation. I was going to put 9v tracks instead of 12v tracks. So, what I understand is that 9v trains get powrs from 9v controllers and leve cossing motors get power from 12v train controller right? thanks again. That's right, it will be fine
