Posted April 26, 201410 yr Hi, I am trying to make a gearbox with 2 frames. I am trying to make it 1:1 and 1:2 1:3 Is this possible? EDIT: the gears could be outside of the frame. Just the gear changer on the inside. Here is a photo http://www.brickshel...go/gearbox.tiff Thanks :), NXT45 Edited April 27, 201410 yr by NXT45
April 27, 201410 yr if i can suggest you something try making the gears closer as possible....for example 1:1 and 1:2 so when you shift gear the transition is smoother :)
April 27, 201410 yr Author i think the gearbox wont fit in the frame. not enough space for the gears. If they are out just a bit that would be fine tho.:) if i can suggest you something try making the gears closer as possible....for example 1:1 and 1:2 so when you shift gear the transition is smoother :) Ok i will do that if I get a design. Edited April 27, 201410 yr by NXT45
