You made me went to check the building instructions... :)
That one I don't think it is illegal. It is a long friction blue pin, and it is not under stress. It connects a 2L equivalent.
  • Replies 55
I prefer to attach trans-colored/trans-clear parts to use as lights, with the stud squeezed into a pin hole. And as kieran says, I think it's been done by TLG themselves.
If it's an "illegal" building technique, why does TLG do it?
Have single studs not been inserted onto liftarms to represent lights befor by LEGO?
Connection by a single stud into a technic hole is legal, connection using multiple holes isn't because it makes the pieces too difficult to separate.
I don't remember one immediately, but most likely yes.
In some case these are connected using half pins also.
But being more precise in my comment, this is the rule.
"Technic holes are slightly smaller than those of System. You can connect a single stud into a single Technic hole and a child can still take them apart. Any more than that and the resistance becomes too great and there is the potential for elements (and children) being stressed."
So technically you can connect single studs into pinholes, but you're still stressing the elements because their dimensions are not 100% compatible, so I believe it should be avoided. Although I use it too! :classic:
There is a bump on the pin (In the middle of the 2L part of it that is being slightly compressed because that bump is now in the middle of a liftarm... It is meant to completely go through a liftarm and then relieve that stress when it goes through the other side... That bump is there for a reason...
This pin being used this way by Lego is the sole reason why I used it in a similar way in the top of the transmission in my Vampire GT....
I don't think Lego had ever used a 3L pin in this manner before the Excavator...
Edited by Paul Boratko
Source, page 12. You can find more illegal connections there.
I was thinking of that too. It was brought up in an old post before.
Page 21 was done in a regular set and page 29 has the Technic.
I insert more tha 1 stud in all the time and there not damaged at all
Have you checked your fingers/nails for damage? :sweet:
Couldn't you just pop them out from the other side with a pin or axle? Sometimes it is very difficult to separate two 1x2 plates that are clicked together. :laugh:
this is really no valid reason because very often it is quite impossible to separate two studded plates when clicked together - neither for children nor for adults... at least not less difficult than separating studded plates with more than 1 stud from technic holes...
The diameter of a technic hole and a system stud differ, so this type of connection has more friction than a standard stud-to-tube, and is harder to remove. Making more of these connections with a single piece multiplies this friction.
Isn't the logic for this connection being illegal that simple, and quite different from legal multiple stud-to-tube connections?
Ok, I saw this and had to join to comment.
Multiple studs into multiple Technic holes HAS been done before by TLG. Space Shuttle from the System end of things. They put the 3 studs from a 1x3 plate into the three holes on both sides of a 1x4 technic block (See step 11). Then the engines attached to it.
That Shuttle set came out right around the same time that the Technic Shuttle did(Give or take a year)
Maybe that was the model that pushed LEGO to declare using that technique "illegal"
Putting plates on both sides of a Technic brick would eliminate the possibilty of pushing one out with a pin or axle from the other side since both are covered... Perhaps they received a lot of complaints about that set...
I know that 8466 and 8448 have a plate with the studs in pin holes, it's used in the door opening mechanism ;-)
Tibivi
The reason why I don't like putting studs in technic holes is that only part of the stud is in contact with the hole, since the hole is wider at the edge.
