At the start, you said you had to build double-thick walls to hide the toothy floor edges. The nice thing about double thick walls, is you can make the interior a different color. Very few houses are the same color inside and out.
Yes, but making different colors between inside and outside is not so easy and if you check accurately you can see that only front and rear wall ha 2-bricks thickness, while lateral walls has just the base, while the upper part is 1-brick (for the living room) while in case of the kitchen is just 1-brick thick (the toothed floor is covered by the furnitures).
Eventually I had to reduce rooms again and I don't like little rooms.
I'm very impressed with the result Kevin8! You have used many interesting techniques with some unusual part combinations. That's the beauty of Lego. :laugh: it's hard to imagine that your creation took 6000 pieces! What is your next project?
Great start and great finishing! I love the roof with the snot part that reminds me of the Fabuland roofs :) My favourite room is the kid's room, you have some nice ideas that I could use someday :) You mentioned you'll re-do the rooms someday. What's wrong with them?
Thanks.
I don't know actually. Thank you!
No... maybe I made some mistake while writing, but I'm not going to re-do the rooms. The only thing I would like to do is the garden...
  • 4 weeks later...
Thank you both.
I'm developing the last part. I'm going to add a garden in the rear. This is simply going into my personal diorama so the garden will fit in it.
  • 1 year later...
