Hi!
Soon, I'll show to you new little rally car with rear independent suspension and rear drive. But rally car must be AWD, so I build small front suspension :grin:
*cardan has free lift under load without stoppes
I'm going to build audi quattro or toyota celica with this system. May be you have another ideas for it?
Thanks!
Impressive. I eagerly await a vehicle with this setup.
v/r
andy
I too.. :laugh:
P.s.I'm waiting for one question so answer it now: "Why i don't use efferman system(http://www.eurobricks.com/forum/index.php?showtopic=60459&st=1375#entry1895722) or sth like that?"
Firstly, I can't use little wheels with new steering portal. Secondly, clearance very small with this portal.
P.p.s I use unusual wheels :laugh:
Finally a way to make small realistic 4wd cars! Great job! Looking forward to rally car, possibly a kind of hatchback style so you could fit an interior and still have room for battery box.
Fantastic!! I've been trying to come up with something like this for ages......
A small compact suspension without all the fancy linkage pieces (that I wish I had :sceptic: ).
impressive :) I wonder if this is possible with 80-90s technic parts only. One question that I have, how it is working in real without the differential?
You gave me an idea which I will try to test, thanks.
regards
Edited by AOW
Thanks you a lot!
If somebody will build it, using silicone grease in shock absorber. It will start work better :blush:
Brilliant creation. How will your steering work with a servo? Servo is probably a bit large for your model anyway.
H :thumbup:
Yes, servo is quite big, also it turns 90 degrees, and it is too much :sceptic:
regards
I have a car with rear suspension and drive like this. It work not bad, so I hope this system will work ok too.
Edited by gsia17
Clever idea for using the spring out of a lego shock over an axle, saves space, is linear and is very useful not just in cars but in mechanisms themselves.
One question - have you considered using 87408.jpginstead of 48496.jpg, and using a 20t single-bevel gear to drive the axle? That way you could get the center of the U-joint lined up with prop shaft axle, and both half-shafts would be of equal length.
EDIT: it wouldn't quite line up, but it would get you 1/2 a stud closer to lining up.
Edited by Hrafn
Thanks :classic:
Reminds me of the twin I-beam suspension found on the older Ford vehicles. :thumbup:
I hope that I never buy a real car with system as my :wacko:
One question - have you considered using 87408.jpginstead of 48496.jpg, and using aea 20t single-bevel gr to drive the axle? That way you could get the center of the U-joint lined up with prop shaft axle, and both half-shafts would be of equal length.
Movement is so small, that it doesn't matter. Also I prefer use 12t gears because that i can use buggy motor directly without additional gear.
P.s. I start build Toyota Celica.
  • 8 months later...
I plan to do that, with due credit of course, even if I end up modifying it. I noticed this video on YouTube months ago and already tried both RWD and AWD, together with the small rear setup and a buggy motor.
Problems I found so far:
1. RWD can't steer, I guess due to the lack of differential
2. When going full speed backwards and the giving full throttle forward, the CV joints pop out of place. U joints resisted that, but the problem only really happened when forcing the RWD setup.
3. CV axles are too short and wheels eventually go away, I tried 4L axles with U joints and still had the same problem, so I think I'll uses 5.5L even though it will look ugly.
Other than that, this is a wonderful suspension setup and I hope you (gsia17) are fine with others reusing it :)
In any case, thank you so much for the inspiration you're giving us already!
Edited by miguev
Thanks for usefull recall)
Hi I was wondering if I can use this system and your other rear suspension one of my projects. All of the credits will go to you Gsia17.
Thanks in advance.
Certainly use it! I will be happy if my ideas will find a place in your models. Hope you show me the result :wink:
Thanks! Yes, at the moment, I have not found the solution this problems, but as soon as a good idea come - I'll fix it. :blush:
  • 5 months later...
