veryhappy Posted July 9, 2014 Posted July 9, 2014 (edited) This is my entry for the mini contest. The main function of this model is given by the two manual operated helices. It has an openable cabin too. I have modeled it on LDD and it uses 200 pieces that mostly came from a 9394 set with a few from 42006, 42022 and 42020. This is a LDD screenshot so you can see how it looks And this is the LDD file https://dl.dropboxus...chnic/Plane.lxf Following these links you will find some more photos of the real thing (sorry for the quality of them): https://dl.dropboxus...26-42_photo.jpg (lateral image) https://dl.dropboxus...-27-35_deco.jpg (above image) https://dl.dropboxus...-28-15_deco.jpg (front image) https://dl.dropboxus...-28-53_deco.jpg (bottom image) I hope you like it PD: I know it has some oddities like the steering wheel (the sports one should look _much_ better ) or the colors of some pieces but, unfortunately, this is the model I'm able to construct Edited July 11, 2014 by veryhappy Quote
NXT45 Posted July 11, 2014 Posted July 11, 2014 Wow nice job! It looks like you spent a lot of time on this! Keep up the good work! Just one thing, you need a photo of all the pieces laid out together. Quote
veryhappy Posted July 12, 2014 Author Posted July 12, 2014 Thanks for the comment You can find the photo of all pieces in https://dl.dropboxus...29-53_photo.jpg (Again, sorry for the quality of the photo) Quote
legomuppet9 Posted July 12, 2014 Posted July 12, 2014 (edited) To take better photo's take a look at Sariel's excellent tutorial - http://sariel.pl/201...ssing-tutorial/ Good photo's make models stand out a lot better, which this model should be Edited July 12, 2014 by legomuppet9 Quote
veryhappy Posted July 13, 2014 Author Posted July 13, 2014 Thanks for the advice. I will take new photos and try to enhace them following that tutorial . Anyway I have noticed that the model I built had two spurious pin and half pieces (part #32002) left from previous tries so I will have to take the pieces photo again . Instead of replacing the old photos I will ad links to the new ones as soon as I have finished them. Quote
veryhappy Posted July 24, 2014 Author Posted July 24, 2014 I'd managed to take a "good" photo and made it clear And in bigger resolution in https://dl.dropboxus...ne modified.jpg This is a photo with the correct pieces: And (just in case you need it) in bigger resolution in https://dl.dropboxus...lane pieces.JPG Quote
W3ird_N3rd Posted August 10, 2014 Posted August 10, 2014 (edited) [edit] This post could have been considered offensive. [/edit] Edited August 10, 2014 by W3ird_N3rd Quote
