well what can I do for this this is about the only way to do this in legos and ldd give me your thoughts
14853624399_2d224a18a6.jpgdoor & back wall final1 by vc597552002, on Flickr14853624049_900afe669a.jpgcockpit door7 by vc597552002, on Flickr15040342875_90058afeab.jpgcockpit door6 by vc597552002, on Flickr15037289731_e7911985b3.jpgcockpit door5 by vc597552002, on Flickr15039980462_74d9be18fe.jpgcockpit door4 by vc597552002, on Flickr15040343635_a2f64e3b8a.jpgcockpit door3 by vc597552002, on Flickr15037290121_0b65d8e966.jpgcockpit door2 by vc597552002, on Flickr15039981202_25c87a106e.jpgcockpit door1 by vc597552002, on Flickr14853753048_53e1c4bb07.jpgcockpit door by vc597552002, on Flickr
Edited by vc59755
  • Replies 99
  • Views 28k
Posted Images
ok here it is all done for the cockpit :what?:
and please give feed back or idea's please!!!!
15049040695_7905d877bb_q.jpginside hall2 by vc597552002, on Flickr14862485297_b959bb5549_q.jpginside hall1 by vc597552002, on Flickr15048683852_1c49113432.jpginside hall by vc597552002, on Flickr14862449658_9bc17138e3.jpginside hall 9 by vc597552002, on Flickr14862316259_0b9df5de62.jpginside hall 8 by vc597552002, on Flickr15026043086_5bbbde5f25.jpginside hall 7 by vc597552002, on Flickr15049041435_a5566140b0.jpginside hall 6 by vc597552002, on Flickr14862449928_84db54534c.jpginside hall 5 by vc597552002, on Flickr15048684332_99c9e4da19.jpginside hall 4 by vc597552002, on Flickr14862485977_a858e76d75.jpginside hall 3 by vc597552002, on Flickr15048684472_fb8f121145.jpginside hall 0 by vc597552002, on Flickr
cross section if any one has any ideas let me know I am open to all options and ??
and this is inner wall padding
as for joining the two walls inner and outer is not fun
15051001295_c9244b688b.jpgfinal cockpit tub inside out by vc597552002, on Flickr14864408168_2231a9b682.jpginside padding1 by vc597552002, on Flickr15028003346_6f5e1e271b.jpginside padding by vc597552002, on Flickr14864336760_c6a10ee7c6.jpginner wall3 by vc597552002, on Flickr15050996975_eb3f4b22b4.jpginner wall2 by vc597552002, on Flickr15028003066_c64a3f2e77.jpginner wall1 by vc597552002, on Flickr14864444257_546b264901.jpginner wall by vc597552002, on Flickr14864408728_884036458f.jpgcross section5 by vc597552002, on Flickr14864404568_cf74357cc9.jpgcross section4 by vc597552002, on Flickr14864264619_ee439513f1.jpgcross section3 by vc597552002, on Flickr14864265649_da0764122f.jpgcross section2 by vc597552002, on Flickr14864409968_bd1f9cd82d.jpgcross section1 by vc597552002, on Flickr14864344470_55a0bb512e.jpgcross section by vc597552002, on Flickr14864273419_483154dd21.jpgcross section door1 by vc597552002, on Flickr15051004955_81f767d160.jpgcross section door by vc597552002, on Flickr15051004955_81f767d160.jpgcross section door by vc597552002, on Flickr
This is coming along great, you are really capturing all the detail. Thos leaked pictures might help you more too! I am more impressed by how fast you are making progress. I would not have time for this sort of project.
A very inspiring project, I really admire your energy :)
Is the landing gear and cockpit to scale? Will you fit a technic skeleton in between the inner and outer wall? I'm a huge fan of the inner/outer hull thing :) If you keep this up it could become the next huge ldd thing - like the recent SSD. Just to remind others here, that SSD also lacked much of its internal structure when first posted, but it was still bat s#!t crazy :D
Amazing progress, I can't believe how fast you are doing it.
Wouldn't tan be closer to the right colour than dark tan for the padding on the walls?
it would if I could ldd does not have it or not in all bricks
Edited by vc59755
Ldd has all bricks in all colours just use expert mode
Yeah VC, click on the "view" tab, then to "new themes", then you will see "LDD Extended". This has all the pieces in LDD in every color, even ones LEGO doesn't produce.
yes I know im just following legos guide lines soi can upload it there
I think you've made great work so far, and I really appreciate your invest in time. :classic:
You wanted suggestions, so I have a few:
- as for making the Falcon EP VII like, I think you should restrict yourself to the OT design. Most references online are from OT, and making it EP VII like will make it impossible to make the entire MOC like VII, as that movie is not out yet, so looking for ref pics of that one is extremely hard. Working that corridor back to OT will be much work, so you may keep it that way if you like.
- Make brick-built figs on the scale you want to, to make it more awesome as there's more of a sence of scale. Now for example, I can't imagine how the same person that can walk in that corridor, fits in that chair.
I think reason why not many people have given you tips is because actually you can find all your suggestions from reference material, and you will not have to use big pieces that limitate detail, so people giving you tips of what element to use for a shape is rare because most are obvious themselfes. If you'd like more input, ask a question in which you are in dubio for your MOC, e.g. you don't know if to use either color A or B or either piece A or B, which is best/sturdiest, that way you can get more input from people.
keep it up, your somewhat 1/<insert large number here> done :wink:
Great work! To improve, perhaps add a technic structure to keep the parts together?
ok here is rough draft of nose of body please check my angles if any one has any ideas please speak up
of if any one has a wing they can check for me i thing it is about 26.5 degrees witch is pritty close to all drawing that i have
and sorry for delay got all my parts in have been building like mad some 600 1x2 1/2 hindge plate
i did find that big of tub will need 4 rows of support on it one on inside 3 out other than i can make it do what i want it to do for back up i wrapped it in some Wire Cloth to keep it shape just in case and is were i got to before new pc parts came in
Operating System
Windows 7 Ultimate 64-bit SP1
CPU
AMD FX-9590 71 °F
Vishera 32nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 802MHz (11-11-11-30)
Motherboard
ASUSTeK COMPUTER INC. CROSSHAIR V FORMULA-Z (Socket 942) 85 °F
Graphics
SHARP HDMI (1920x1080@60Hz)
4096MB ATI AMD Radeon R9 295x2 Series (ATI) 112 °F
Storage
465GB Samsung SSD 840 EVO 500G SCSI Disk Device (SSD) 79 °F
1862GB Western Digital WD My Book 1140 USB Device (USB)
1863GB Western Digital WDC WD20 EARS-00MVWB0 USB Device (USB (SATA))
1863GB Western Digital WDC WD20 EARS-00MVWB0 USB Device (USB (SATA)) 88 °F
2794GB Western Digital WDC WD30 EZRX-00D8PB0 USB Device (USB (SATA)) 88 °F
2794GB Western Digital WD My Book 1230 USB Device (USB (SATA)) 96 °F
1863GB Seagate ST2000DL 003-9VT166 USB Device (USB (SATA)) 108 °F
1863GB Seagate ST2000DL 003-9VT166 USB Device (USB (SATA)) 105 °F
1863GB Seagate ST320005 42AS USB Device (USB (SATA)) 105 °F
2794GB Seagate ST3000DM 001-1CH166 USB Device (USB (SATA)) 112 °F
Optical Drives
DTSOFT Virtual CdRom Device
hp DVD A DH16AAL ATA Device
Audio
AMD High Definition Audio Devi
15000135847_91b52ab7e3_m.jpgleft nose peace1 by vc597552002, on Flickr
14999922289_1fddbcc2cf_m.jpgleft nose peace by vc597552002, on Flickr
Hello vc!
This is really ambitious project. The size you picked is huge. I'm just wondering, do you plan to ever build this in real? As many guys said already, there aren't any supporting frame structures, so far, I think that only your landing gear would hold together. Everything regarding cockip and the entrance corridor looks extremely fragile and I'm 100% sure that it couldnt hold its own weight. Otherwise it's really cool and detailed. And the speed of your progress is mind blowing - I hope it's not the result of no care about structural elements.
kris
ok looking for so input on the hyperdrive generator
my scaling is as follows
1b = 3" scale 1' = 1.5" = 4 bricks
2b = 6"
4b = 1' = O O O O
5b = 1'3"
10b = 2'6"
20b = 5'
40b = 10'
IF YOU COME UP WITH SOMETHING POST IT
I would realy like to see what other come up with
my final size is no more than 36x36x40 in bricks or 9'x9'x10'
15104250628_2506ea0a5a.jpgmillenniumsheet2 by vc597552002, on Flickr
15104259887_ebc6f65b99.jpgSSP05_hyperdrive_generator by vc597552002, on Flickr
  • 4 weeks later...
Hello vc59755, any progress in the last week's. I'm following this topic. I'm very curious how far you are now. Good luck!
