Posted August 4, 201410 yr Hi I want to share my latest creation with you. It's a pickup truck, remotely controlled by PF. Differentials on both axles, and a centre differential. The rear axle might seem to be fragile, but with some maintenance now and then, it actually does it's job. The front axle got a positive caster angle, at the cost of poor ground clearance. More pictures can be found at http://mocpages.com/moc.php/393987 A small video of the truck in action: (I'm sprry for the bad quality and poor editing ) Edited August 4, 201410 yr by Petter
August 4, 201410 yr Nice pick-up the functions are there but the bodywork could be improved more. Welcome to Eurobricks. Edited August 4, 201410 yr by Alasdair Ryan
August 4, 201410 yr Nice truck! You don't see many MOCs with centre differentials these days either (well, at least I haven't), so kudos to you!
August 5, 201410 yr Author Nice work! It is very fast. How much does it weighs? Weight is around 1.1 kg. Nice work! My only complaint is that it should have some doors I was a little bit inspired by some Jeeps I've seen without doors, but yes,I agree with you, it looks a bit strange on my model Edited August 5, 201410 yr by Petter
