August 13, 201410 yr Author The geraing is like that: Front axle 1:2 Rear axle 1:5 Differential averages the both gear ratios to 1:3,5 3x gear ratio after diff equals to the total gear ratio of 1:10,5 from the inner (faster RC motor output). Thanks! One more picture: Edited August 13, 201410 yr by Zblj
August 13, 201410 yr Wow, u sure build fast! I must check the LDD for that rear suspension! How long did it take to build it in LDD? Did you waterproof the motor and BB before going scuba? ;-) Best regards
August 13, 201410 yr Author Thanks! It took me some 3,5 hours to make LDD file. No the motor was not water proofed. Thanks!
