Hey for my movie (obviously) I need these ships I'm going to build on water, like an ocean. And a harbor. Originally my plan was to animate these ships on my mom's incredible computer, then put them on moving waters, but that's going to be incredibly hard.
So I was wondering, If you had to get a ship to look like it was in the ocean, what would you do?
Thanks,
-TD
I would not do it on water. First, the ships will sink, as the normal lego hulls can't really float. If you have the 4+ hulls, you could, but still not a good idea because the waves will look like gigantic 100 ft. waves. if it was on the ocean.
You're best to either working in a smaller scale, or blue bricks.
Thanks,
-TD
I think you'd be best of with a big piece of blue cloth. I believe a LEGO film has to be done in stop motion. If you'll use reall wavy water, the wave won't look good. But if you still want to work with water, I suggest you to take a bowl, fill it with water and sand and put the ship on a stand in the water.
If want to know more about this matter, you should take a look in this thread about the LEGO hulls.
I made keel once for a ship with one mid section. It worked quite well... Till I put masts on it. :-P
Mr Tiber
Edited by Mr Tiber
Mr. Tiber, that link goes to replying to this thread!
Well, if you put a beam under it, it should be good. But I would suggest in conditions where you can control the water and keep it as flat as possible. Or else the waves will look like they're jumping when animating.
You're right! How could that have happened? I believe we've had this problem quite some times lately...
I was trying to link to Norrington's thread... I think I made a mistake...
But it's fixed now!
Mr Tiber
Edited by Mr Tiber
Yes, I have seen stop-motion pirate lego animations, and for water, people use blue towels, which looks pretty cool. Another option is to buy a professional editing program like I am going to get, and film the ship on a green-screen (or blue-screen) Then edit in real ocean water, but that would be complicated.
You watched that movie by liquid plastic productions, didn't you?
This is very ironic, because I'm working on a way to make a bottom for my ship's hull, so it floats on water and doesn't look like it's about to sink. My hulls don't sink because they aren't lego. They're a clone brand called Cobi. They have a barrier between each midsection that prevents water from getting in. You might want to snag a few on ebay, but they're way too over priced.
One day a good while ago I was screwing around. I'll upload the results exclusively by your request. X-D
Done. It just needs to be processed now.
You were screwing around Mr Oo7? Are you sure that footage is going to appropriate for this forum? X-D
HAHAHA!!! :-D
Bring it on, I could do with some entertaining.
Of course it's appropriate. What did you expect? X-D
It's done.
I find it ironic...sort of. Towls are a good way for us to make up 'water', even though towels are used to soak up water!
( I was expecting something shinking! Or you ship you posted in the MOC forum from your town....city.)
Darn it.I was gonna say that.
^I've heard otherwise. I think that would be very hard.
That's my plan, but if that fails, I'll just throw in some blue felt/towels, and a decent backround.
oo7, thanks for that that does look okay actually, I might try that before Just blue felt.
Thanks,
-TD
Thanks,
-TD
It wouldn't be very hard, if you had MSN or something I could walk yah through it or do it for yah. I'm a 3D Modeler by trade... so I could help yah if you wanted. Let me know.
Cheers
I know it wont be the best hull for Pirate ships (Ive tryed) But using the hull from the Policeboat or the Fireboat both avalible from the Lego Store.
I tryed to make one but failed 8-(
But there are alot of better Lego builders and i belive you can make one.
