I think you should give it a shot, if you fail, no one has to know :devil:
here's the decals for it, I decided to not do the emblem, but these decals are for the LE TIGRE, fall 1917
15199464321_b4657dda0d_o.pngLego Renaut FT-17 decals by Tommy Styrvoky, on Flickr
original tank
I'm hoping that the color will match the bricks, I used the CMYK numbers of the lego color, I am unable to print them right now but eventually I will.
  • Replies 93
There! I think it came out great! You don't say how did you like it :tongue: What is the function of that "tail" that is still missing (regarding to the original pictures)? Some anti-rolling safety device or what?
yeah that and the engine is missing, it's to prevent the tank from flipping over when going over a trench.
Finally Le Tigre has a Tail, I think it turned out pretty well. It has some slight problems with weight, it can hold in the upwards position but it can fall (it is required to be hinged because on the real vehicle this is where to access the port for the crank starter)
15242226165_58979497a8_o.jpgLego Renault FT-17 by Tommy Styrvoky, on Flickr
15055466739_f8a761d4fc_o.jpgLego Renault FT-17 by Tommy Styrvoky, on Flickr
the port for crank starting is visable
now here are some flaws that I would like to fix before the model is complete (it's about 95% done right now)
15055648257_2f35b9157b_o.jpgLego Renault FT-17 by Tommy Styrvoky, on Flickr
The angles are incorrect and the drivers viewport should be at least 3 studs wide
15055454189_5778e3de77_o.jpgLego Renault FT-17 by Tommy Styrvoky, on Flickr
The gap between the hatches.
Edited by Tommy Styrvoky
I did some work on the engine block, it still needs the header/manifold assembly to go on top of it, that and the tools are all that really remains to build for this model.
15252681942_16d8e28edd_o.jpgLego Renault FT-17 by Tommy Styrvoky, on Flickr
15066485147_cca55cf09c_o.jpgLego Renault FT-17 by Tommy Styrvoky, on Flickr
15066305489_e4e34274bc_o.jpgLego Renault FT-17 engine block by Tommy Styrvoky, on Flickr
I might tweak the hoses/linkages on this side of the engine
15252691632_857a73ddf4_o.jpgLego Renault FT-17 engine block by Tommy Styrvoky, on Flickr
Did you figure out why the turret looks drunk in that picture above?
? do you mean the gap on the back?
I might do some revisions to the turret roof and viewport.
I really like your work here. Nice detailed engine and back.
On one picture it looks like the turret leans to the left. I think that is what Rollermonkey meant.
I added the header/manifold assembly to the engine and I added tools to the exterior of the vehicle, all that is left is to fix the flaws I mentioned earlier or ones that I have yet to notice.
15262197402_6c47b37009_o.jpgLego Renault FT-17 1/15 by Tommy Styrvoky, on Flickr
15075896640_ceb04c279d_o.jpgLego Renault FT-17 1/15 by Tommy Styrvoky, on Flickr
15262206472_ba311e0a26_o.jpgLego Renault FT-17 1/15 by Tommy Styrvoky, on Flickr
15076032408_a0d55788c5_o.jpgLego Renault FT-17 1/15 by Tommy Styrvoky, on Flickr
the engine removed
15262603145_e626bceb40_o.jpgLego Renault FT-17 engine by Tommy Styrvoky, on Flickr
15076041968_c0a8d9640d_o.jpgLego Renault FT-17 engine by Tommy Styrvoky, on Flickr
the whole picture was taken at a angle, so the turret isn't at a angle. Edited by Tommy Styrvoky
I disassembled the model into sub assemblies for taking reference photos for making instructions and I found out that this model could be displayed as a cross-section version, it basically has all of the model except one of the side walls and tracks.
15076231120_a73ee23d74_b.jpgLego Renault FT-17 Cross-section by Tommy Styrvoky, on Flickr
here are some of the different assemblies
15239912656_735b54c7f2_b.jpgLego Renault FT-17 midsection by Tommy Styrvoky, on Flickr
15262553262_7276aa211f_b.jpgLego Renault FT-17 tracks/suspension/wall section by Tommy Styrvoky, on Flickr
15076370038_f1252dca6e_b.jpgLego Renault FT-17 Roof/upper armor section by Tommy Styrvoky, on Flickr
here are all of the components laid out.
15076226720_3205322f1e_b.jpgLego Renault FT-17 components by Tommy Styrvoky, on Flickr
As cool as that cross section is, I think that you can build this via sub-assemblies is a huge plus.
I also love the Imperial Star Destroyer hiding out as the cockpit floor/seat.
Quite a bit of the large pannels are from the 6211-1 imperial star destroyer
I'm not sure you translated my comment the way I intended...
The sub-assembly of the cockpit floor and seat looks like a mini-ISD is sitting in the middle of the rest of the tank sub-assemblies.
I thought about that because of its similar shape, but those white plates are from the ISD.
