dolittle Posted December 25, 2010 Posted December 25, 2010 "We're going to show you how to build a south-pointing chariot, an ancient bit of Chinese engineering – out of Lego. What makes this a neat little piece of steampunk engineering is the fact that if you build it right, the chariot will always point south no matter which direction it travels in, giving you a perpetually correct reference point. And there isn't a single magnet: it's all done with gears. " Toy-de-force: Build your own steampunk Le Hope you like it. Thank, Noam Quote
blueShinyApple Posted December 28, 2010 Posted December 28, 2010 I built one like that two years ago when I was twelve! Quote
Big Cam Posted December 29, 2010 Posted December 29, 2010 I searched the first 3 pages and didn't see this, so enjoy. Build LEGO compass without any magnets Quote
allanp Posted December 29, 2010 Posted December 29, 2010 Looks cool, but why did they add that final stage of gearing down (24t - 40t), would that not make it too slow? Quote
JunkstyleGio Posted December 29, 2010 Posted December 29, 2010 Double posting! The title must be a little confusing Quote
Big Cam Posted December 29, 2010 Posted December 29, 2010 Double posting! The title must be a little confusing Bahh, I knew I should have looked harder, I've requested my thread be merged, thanks. Quote
rgbrown Posted December 29, 2010 Posted December 29, 2010 Looks cool, but why did they add that final stage of gearing down (24t - 40t), would that not make it too slow? No, you need the gearing - this one is a nontrivial exercise. If v1 and v2 are the speeds that the two wheels are travelling along the ground, then the corresponding rotational speeds of each wheel are w1 = v1 / r w2 = v2 / r where r is the radius of each wheel. Doing the maths with the differentials, the rotational speed of the crown gear that links the differentials is then given by wc = 1/4 (w1 - w2) = 1/(4r) (v1 - v2). The angular speed of the overall chariot is given by wt = 1/L (v1 - v2) where L is the distance between the two wheels. So L would have to be four times the radius of one of the wheels for the system to be balanced without additional gearing. For the depicted chariot, I estimate L to be about 17, and r to be about 3. So the compass wheel needs to be geared down by a ratio 4r/L ~ 12/17 ~ 0.7. The 24:40 gives a gearing down of 0.6 (i.e. the right ballpark). I'm sure if you were to actually measure the distances, you'd find those numbers would be very close. Quote
rgbrown Posted January 6, 2011 Posted January 6, 2011 Couldn't resist building one of these for the kids' soldiers and pirates ... this one's been hijacked http://www.youtube.c...h?v=HE1N58tvg5Y Quote
