BurkusCircus Posted August 19, 2017 Posted August 19, 2017 Re: third rail. I actually love this idea because of what could be done with it. I run both Lego, ME Models (track), and Lionel O gauge. Thought I'd share my thoughts on a third rail. 1: With a third rail, you have half the pickup opportunities as using two, and it's very easy to stutter in regards to the pickup's connection. Right now I'm in my system's "Five Year roadblock" - every five years, everything is worn out and needs a mass cleaning. 2: This opens the door to operating accessories. And I don't mean like grade crossings using finicky color or motion sensors. I mean actually wired to the track, activated by the train. It would work like this. Cut the metal of one of the outer rails (use ME if it affects your Lego-only morals), and wire the now-dead section to the accessory. The train should need only one outer rail and the inner rail to run. When the train runs over the other, powered rail, the current will go up the wheel, across the axel, and down the other wheel, onto the dead rail, and power that rail. Then, if the accessory is wired to that rail, it will turn on, and a gate will go down, lights go on, turns on a station announcement, whatever you can image! And then it stays powered until either the train leaves the section or you turn the other rail off. 3: It ruins any realism you may be going for. While a new type of Hi-Rail (really detailed three-rail O Gauge) could come out of it, the much more realistic and likely result will be having it be seen as a toy. 4: It's less accurate. We have the only system that doesn't rely on track power (unless you still cling to 9V...). Think about it. Real trains have a fuel source, motor, and operating system all on board. While they get their operating signals from on-board currently, self-driving trains aren't that far-off. No other system has this. Real railroads (or, more accurately, GE and EMD) have to figure out how to fit a generator. We have to work around a battery box. Our struggles, while we would like for them to go away, are the most systematically correct struggles of all of model railroading. Embrace them. Either that or recognize I've gone crazy. ? Quote
Ludo Posted August 17, 2018 Posted August 17, 2018 @coaster As we see once more a 'new' system from LEGO, i would defenately leave the path of using the 9V connectors. 9v used 2 wire PF used 4 wires Powered up use 6 wires following system use perhaps 8 wires, then we can use UTP or telephone cabling. Guess this kind of connector is worldwide available and cheap too: and the male connector like (90° pins & straight pins - pitch = 1/10 inch = 2.54mm): Quote
coaster Posted August 17, 2018 Author Posted August 17, 2018 I've had some discussions with others on how to tackle this. There's no great answer, but the best solution so far seems to be to keep the wheelsets with the classic 9V connections on them, but we're going to need adapters to handoff between the different systems. Quote
Roadmonkeytj Posted August 18, 2018 Posted August 18, 2018 On 8/17/2018 at 2:24 PM, coaster said: I've had some discussions with others on how to tackle this. There's no great answer, but the best solution so far seems to be to keep the wheelsets with the classic 9V connections on them, but we're going to need adapters to handoff between the different systems. Im late to the game here but space is the main concern in this area . The 9v method is easy enough ... Ive never had a 9v connector wear out ... Unless corroded or the brick snaps due to mishandling. I honestly love this solution ... For this simple reason alone. You can leave an empty wire and self wire or you can provide 9v,pf,pu adaptors on request. On the release of the any lego unit these would be great for coach power. Long game I think a method using the axle style so you can plug them into custom creations would be good. The product as is I would buy. My lug runs 9v but I build my trains pf to run on any layout. I could include this wheelset and run on batteries when on other layouts. Quote
bricknerd Posted September 14, 2018 Posted September 14, 2018 (edited) On 8/17/2018 at 8:24 PM, coaster said: I've had some discussions with others on how to tackle this. There's no great answer, but the best solution so far seems to be to keep the wheelsets with the classic 9V connections on them, but we're going to need adapters to handoff between the different systems. Love it! I could imagine using those wheelsets not only to pick up power, but also to visually complete the metal wheels of the 9v motor on 6-axle trucks, maybe even upgrade my 9v models to all metal wheels. So - count me in :-) Do you have an idea already when they'd become available and for how much? EDIT: Needless to say that the 9v connector would be perfectly fine for me ;-) Edited September 14, 2018 by bricknerd Quote
brickvan Posted November 25, 2018 Posted November 25, 2018 Hi all, I'am new to the forum and in search for.. guess what? a decent 9V pickup solution. Is that the latest & proper thread on that topic? I was not able so far to source proper metal wheels at reasonable cost. @alainneke bricklink shop seems closed :( Is there another way to source such or similar wheels? (I am in the EU) I am like others eager to see how @coaster project for a 9v pickup evolves. Alternatives I've studied a bit so far, should anyone else like me is interested in the topic and want to do her/his own research are reported below. thanks! Udo's pickup solution (copper desoldering braid on train motor decorative side)https://www.flickr.com/photos/ust60/sets/72157629673770619/with/6872190758/http://www.eurobricks.com/forum/index.php?showtopic=63596 Alain's Pickup: https://www.flickr.com/photos/alainneke/with/8438393941/ RailCo's alternate metal / plastic wheels. Pickup using a 9V motor SteveB hybrid 9V-PF motor Another 9v pickup solution from way back that may also interest: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=461894 Quote
Ludo Posted November 2, 2019 Posted November 2, 2019 (edited) On 11/29/2016 at 5:26 AM, coaster said: Thanks. I plan to simply nickel plate the contacts. That's what LEGO has done, and it's certainly cheap and easy to do, and should have no problem holding up to this mild usage. I'd love to see pics! Here's an updated overall shot of the wheelset: A lot of you are concerned about maintaining good electrical contact. The LEGO 9V motor used spring loaded contacts on the metal wheel flange such that the flange always made contact with the rails, and I'm doing the same thing here. Popping the cover, here's what the insides look like: Isolating just the contact tabs, they look like this: As I said before, this has taken a backseat to the tracks project, but I haven't forgotten about it. There's just only so much I can do at once. Hi @coaster, As i see more & more Afol's using ball bearings on their rolling stock, any considarations of implementing ball bearings into the power pick-up wheelset? Edited November 2, 2019 by Ludo Quote
XG BC Posted November 9, 2019 Posted November 9, 2019 (edited) On 8/19/2017 at 3:05 PM, BurkusCircus said: 4: It's less accurate. We have the only system that doesn't rely on track power (unless you still cling to 9V...). Think about it. Real trains have a fuel source, motor, and operating system all on board. While they get their operating signals from on-board currently, self-driving trains aren't that far-off. No other system has this. Real railroads (or, more accurately, GE and EMD) have to figure out how to fit a generator. We have to work around a battery box. Our struggles, while we would like for them to go away, are the most systematically correct struggles of all of model railroading. what about electric locos? they dont have any fuel source onboard. i mean yes they got transformers and stuff on board but that stuff is still wayyy smaller than the HUGE battery boxes that lego gives us. I tried to build my own power pickups a while ago wich would whipe along the track but this idea wasnt succesful since i had constand contact problems and couldn't drive across switches. I am now getting my hands on some O gauge wheels to modify using this method: https://m.youtube.com/watch?v=nDKTOyN4uzw XG BC Edited November 9, 2019 by XG BC Quote
coaster Posted October 28, 2020 Author Posted October 28, 2020 As it's almost Halloween, a little project (and subsequent thread) necromancy seems in order. I've had time while waiting for switches and other things to come in, so I made some new prototypes utilizing ball bearings and made the cover facades removable. I've minimized the footprint to the best of my ability. No idea on what it would cost to mass produce, and frankly I'm not sure I want to deal with another production project yet either. But here it is nonetheless. Quote
BrickMusher Posted October 28, 2020 Posted October 28, 2020 Hi Coaster, definitely a nice one. Would buy a couple of them instantly. If you dont plan to mass-produce yet, maybe a small pre-production I can test for you? Would like to start with a dozen or so. Is the metal wheel-flange an original part? Quote
coaster Posted October 28, 2020 Author Posted October 28, 2020 Haven't decided about production yet. I for sure need to let the dust settle on everything else first. Unfortunately, these prototypes cost me about $100 apiece to build and take 2 hours to assemble. Production would certainly be better, and would only take a few seconds to assemble, but making the prototype involves scavenging ports from various LEGO elements, including a 9V motor. Its sacrifice will not be in forgotten. Quote
brownie5968 Posted October 28, 2020 Posted October 28, 2020 3 hours ago, coaster said: Haven't decided about production yet. I for sure need to let the dust settle on everything else first. Unfortunately, these prototypes cost me about $100 apiece to build and take 2 hours to assemble. Production would certainly be better, and would only take a few seconds to assemble, but making the prototype involves scavenging ports from various LEGO elements, including a 9V motor. Its sacrifice will not be in forgotten. That prototype sure looks good, surely you could run wires from the wheelset and use them to power things within the loco, also, what about the old 9v plates? could they be sacrificed to make wheelsets? sorry if i seem dumb here, but the idea behind this is somehting id totally be behind, even just for a mechanism that works that could be modified to be 3d printed for use on standard gauge hobby track ie O-gauge Quote
coaster Posted October 28, 2020 Author Posted October 28, 2020 Some 9V plates were used in the creation of this prototype, yes. Quote
M_slug357 Posted October 29, 2020 Posted October 29, 2020 @coaster Something I’ve been toying with recently are LGB wheels with metal tires/flanges. I found a few different sizes that are equivalent to BBB’s M, L, and xL size drivers. Even more interesting is that the diameter for the plastic rim of one wheel size is close (+|- 1~2mm) to that of the outside diameter of a blind driver from the next wheel size down. Basically, a blind M driver could fit into the metal tire of an L. Quote
legoboy3998 Posted October 30, 2020 Posted October 30, 2020 On 10/28/2020 at 8:02 AM, coaster said: Haven't decided about production yet. I for sure need to let the dust settle on everything else first. Unfortunately, these prototypes cost me about $100 apiece to build and take 2 hours to assemble. Production would certainly be better, and would only take a few seconds to assemble, but making the prototype involves scavenging ports from various LEGO elements, including a 9V motor. Its sacrifice will not be in forgotten. I see great possibility in these! For railcars, allowing power pickup for lighting, EOT devices, and even sound (Soundtraxx SoundCar}. For locomotives, allowing a power pickup truck and a PF Train motor truck, adding a power pickup wheel set to the standard PF train motor for three axel trucks, for technic motor drive trains, using one or two pickup wheel sets, and one or two drive wheel sets, depending on truck type and builder's desire. If (and that is a big if as I know it would take significant time, money and effort to get it into full production) it could be released at a similar time to Fx Bricks metal track system, I think both would work well together to increase demand and usage for each other. Sal WFB, WI Quote
