  • Replies 3.4k
Posted Images
Very elegant! The module is quite compact when the legs are withdrawn. Will you be controlling the horizontal and vertical motions separately or will they be linked?
Iam not sure at this time. And iam not not sure if the truck will be RC. RC would be fun to play, but with gearbox it will be a challenge to get all the functions in this size.
with a half stud offset, which the angled beam has, the gap will not really closed. and with only 4 studs overlap it will bend upward. the other handicap of this stabilizer design is that it blocks the chassis and no axles can go through the stabilizer box. so i have modified the outriggers a bit. The box is much more fat, but i have more stabilizing width (33studs) and the frame is free for drivetrains and something else.
ok, they are better than nothing, but please take a look at this picture
101_9398 von efferman auf Flickr
can you see the problem?
edit
is it not funny? i want add a portal axle and what iam doing? a whole new chassis :laugh:
101_9402 von efferman auf Flickr
and why iam build so many times a chassis like a unimog?
What kind of brick is it next to the L-shaped brick on the axle?
I have never seen it before.
Best regards.
Naa, I meen the dark grey triangular brick next to the black L-shaped one.
Seen on pic 3.
Looks like 44135. Along with 44136 it's one of the few Bionicle pieces that's reasonably useful for Technic.
The length overall is the same, but the wheelbase is two studs longer to get the two PF-L in the front. The other L motor sits above the fake engine and powers the wheel. A M motor is placed under the drivers seat and is used for steering.
