Jim Posted October 21, 2014 Posted October 21, 2014 C-MODEL CONTEST ENTRY TOPIC This is the entry topic for the Technic C-Model Contest. DESCRIPTION Build an alternate LEGO Model out of one or two existing LEGO Technic sets. The total part count for the set(s) you use can't exceed 600, so you can either use a single set containing 600 parts or less or use two (different) sets with a combined part count of 600 or less. You can't use 600 parts of a 1200 part set. Since 2005 is the year I came out of my dark ages, I am also imposing a release date limit. The set(s) need to be released in the year 2005 or later. DEADLINE Deadline date is November 30th, 2014. Contest will be closed on Monday the 1st, so you will have the entire Sunday to build. CONTEST INFORMATION More information about the contest can be found in the general discussion topic. WHAT DO I NEED TO ENTER? Please take a careful look at the rules before posting in this topic. Each participant is obliged to create a post in this entry topic. Posts need to follow the rules stated below. Posts not following the rules will be disqualified so please read them carefully. ENTRY POST The entry post should contain: Name of your model Picture(s) of the original model(s) Short summary of the functions/features One or more (max 5) pictures of your model Link to your [TC5] topic Optional picture of leftover parts Optional video of your model IMPORTANT This topic should be used for entries only, so commenting is prohibited. Please use the general discussion topic for comments on the entries.
mescalinum Posted November 4, 2014 Posted November 4, 2014 1. Mars Rover Hello everyone! This is my TC5 contest entry. It is a planetary exploration rover (something like the NASA Curiosity Rover). It is built from set 8264 Hauler. This set was released in 2009 and counts 574 parts, including a Power Functions M motor, and a linear actuator. Model name: Mars Rover Features: - articulated rocker-boogie system like in the real rover, for the 4 rear wheels - arm turntable can be rotated by a crank accessible below the vehicle (hand of devil?) - arm lifted by Power FunctionsTM- - power switch easily accessible from a lever on the rear - solar panel inclination controlled by a pot hidden in the chassis - other movable parts: claws, antenna, camera Pictures: Leftover parts: Video: Discussion thread: [TC5] Mars Rover
ms09 Posted November 6, 2014 Posted November 6, 2014 2. Sidecar Motorcycle Hello everyone, Here is my TC5 contest entry based on parts from set 9392 and set 42001: Original thread. Name of entry: Sidecar motorcycle 亞也虎 Features: Functioning fake engine, Functioning steering, Rear axle suspension, Turnable hood of sidecar. Pictures: Leftover of 9392 and 42001:
rumpletump Posted November 6, 2014 Posted November 6, 2014 3. Pull-Back & Go-Kart Combo- 42002 42026 Functions- Pull-back and go. Working 2 cylinder piston engine . Adjustable height steering wheel. Features- Accelerator and brake pedals. Rear brake disks. Info- Parts available 305. Parts left over 54. [TC5] WIP Thread- http://www.eurobrick...howtopic=101857 Images-
jono rocky Posted November 7, 2014 Posted November 7, 2014 (edited) 4. Eagle 9394-LK Helicopter G'day everyone. This is my TC5 contest entry. It only uses the Technic set 9394 Jet Plane. The discussion thread for this. I call it the EAGLE 9394-LK HELICOPTER Functions: Free Rotating rotor blades. Removable swivel undercarriage gun. Removable rocket/missile wing store pylons. Retractable front main wheels. Retractable handle for one handed use to lever to spin main rotor blades Geared and sprung lever to spin main rotor blades. Movable pilotage system. Original set and model. My Model Leftover pieces. Edited November 30, 2014 by Jim
MrTekneex Posted November 8, 2014 Posted November 8, 2014 5. Beach buggy Alternate from set 8081 General information: Dimensions: 31x13x16 cm Weight: 540 grams. Pieces: 549 Functions: - HOG steering - Fake v4 engine - Full suspensions - Working steering wheel. From the top From the back Discussion thread Leftover parts (41 pieces): The video: PDF Building Instructions available @ my website.
MajklSpajkl Posted November 8, 2014 Posted November 8, 2014 (edited) 6. The Dawnbreaker This is an alternative model built from sets 9392 Quad Bike and 42026 Black Champion Racer. Features: - independent front axle suspension, - dragged rear axle suspension, - RWD by a pull-back motor, - chain driven single cylinder fake engine, - automatic return-to-centre steering provided by a super positive caster angle (steering is done by the steering wheel in the cab), - manualy adjustable rear wing, - only stickers from 42026 used. There are 54 pieces remaining out of 343 available (including spare parts). You can read more about The Dawnbreaker in the discussion thread and build it using these. Edited November 30, 2014 by MajklSpajkl
Renamed99 Posted November 8, 2014 Posted November 8, 2014 7. Kirovec K700 made of 42021&8282 sets Functions : Working fake engine Articulated steering (kind of) The back of tractor is adjustable Adjustable cultivator Original topic: http://www.eurobrick...howtopic=102152
pint14 Posted November 8, 2014 Posted November 8, 2014 (edited) 8. Vintage Motorcycle Made out of 42007 and 8048. Functions: Rear and front suspension. Working piston engine. Steering. Edited November 30, 2014 by pint14
TGBDZ Posted November 10, 2014 Posted November 10, 2014 (edited) 9. Wheeled Excavator Discussion thread For the [TC5] challenge I'm using 8071 Bucket truck And this is my model Functions: Working Steering via the gear on the back Front grader can be raised up or down Feet on the back side can be lowered, and raised Rotation of the upper structure via the gear on the side Boom can be raised and lowered Bucket is fully operational too Here you can see that functions are controlled by yellow gears on the right side of the excavator. The brown gear at the back controls steering. Front grader and rear feet are controlled manually. And the spare part photo - 55 parts left Video of functions can be found here (Older version of my model is seen in the video + sorry for the low quality) https://drive.google...w?usp=sharing�� Edited December 1, 2014 by TGBDZ
BusterHaus Posted November 12, 2014 Posted November 12, 2014 10. Irish Rover Features Independent suspension on 4 wheels All-wheel steering HOG steering Opening doors Adjustable seat Motor (operated by hand) with balanced piston Functional car jack Video [TC5] Thread
BigCatBoy Posted November 14, 2014 Posted November 14, 2014 (edited) 11. Civilian Batpod ORIGINAL SET: 8420 Street Bike FUNCTIONS: Steering (with a HUGE turning radius!). Suspension in the mid-section of the bike. Animated boxer-4 motor connected to rear wheel via chains. Opening panels to view suspension and motor. Kickstand on right side at rear. Windshield, can be pivoted a little. Separate stand that's sturdier than the little kickstand. Link to the entry topic: http://www.eurobrick...howtopic=102036 Lego Technic Set 8420 Street Bike Edited November 30, 2014 by BigCatBoy
robertdeartois Posted November 14, 2014 Posted November 14, 2014 12. Half-Tracked Grass Cutter Hi everyone! I've built my TC5 contest entry from set 42004 and set 9391 Name of entry: Half tracked grass cutter 1, Working steering 2, Rotating cutter blades while pulling the machine forward or backward 3, Adjustable cutting blades angle 4, Working windlass 5, Although it's not a function, but the machine has a set of spare wheels grass cutter discussion topic pictures:
Dalafik Posted November 15, 2014 Posted November 15, 2014 13. Front Engine Buggy Sets used: 42005 Monster Truck and 42021 Snowmobile Functions: independent front & rear suspension; working steering wheel; openable cabin. Discussion thread: http://www.eurobrick...12#entry2054834
izorn Posted November 15, 2014 Posted November 15, 2014 14. Motorboat sets used: My build: Functions: -steering Discussion thread http://www.eurobrick...howtopic=102430
jyd80 Posted November 18, 2014 Posted November 18, 2014 15. Snow Groomer Snow groomer made with the 8047 "Compact Excavator" from 2009: There are three functions: Lift of blade (left exhaust pipe, worm gear, 24t crown, lift arms) Lift of tiller (right exhaust pipe, worm gear, 8t, lift arm) Working tiller, driven by the caterpillars (12t-12t, 2 times). In addition, the blade is manually steerable (pin with friction). Some more views to see the mechanisms: For a bit more details, see the discussion topic!
CharlieBravo Posted November 19, 2014 Posted November 19, 2014 16. Ferrari 458 Sets used: 42004 - Mini Backhoe, 246 pieces 8067 - Mini Mobile Crane - 292 pieces My Model: Functions: HOG steering Opening Doors Folding Roof More photos Link to TC5 thread:http://www.eurobrick...howtopic=102546 -CharlieBravo
326 Posted November 20, 2014 Posted November 20, 2014 (edited) BrumBrum Removed Edited November 30, 2014 by 326 Removed some images (max 5)
sm 01 Posted November 21, 2014 Posted November 21, 2014 17. Daydream Hello everyone, my C-model for the contest was made out of a Quad Bike (9392) and a Black Champion Racer (42026) parts. I called it "Daydream" Functions: - Suspension: Independent front, dragged rear axle - Steering: Working steering wheel - Pull back motor (RWD) with a locking mechanism - Openable scissor doors - Extendable/retractable front part of the car - Adjustable rear wings Dimensions: Length: 22-24cm/ Width: 15cm/ Height: 9cm. 329 pieces used out of 343 (spare parts included). Weight: 332g. 14 leftover parts: Functions are presented in the video: Please note that the video was made before final changes to the model, more details can be found in the discussion thread: http://www.eurobrick...howtopic=102480
veryrusty Posted November 23, 2014 Posted November 23, 2014 18. Dune Buggy My entry for the TC5 contest is a dune buggy. Looking at it again, it does look like it might actually fit in better to a toy story theme, with a pair of goggly eyes. Discussion thread is here: http://www.eurobrick...howtopic=102683 It is built from 42021 and 42022 for a combined total of exactly 600 parts. Features Transversely mounted V6 engine Front and rear suspension HoG and steering wheel steering Pictures IMG_2156 by veryrusty82, on Flickr IMG_2154 by veryrusty82, on Flickr IMG_2152 by veryrusty82, on Flickr IMG_2151 by veryrusty82, on Flickr IMG_2153 by veryrusty82, on Flickr Leftover bits Far too many Tc5 contest by veryrusty82, on Flickr
Seasider Posted November 23, 2014 Posted November 23, 2014 19. Can-Am Style Race Car Original Model: 42022 Hot Rod (414 pieces) .. and my C model Features : HOG Steering Working V6 with solid rear axle Parts left over : 67 Discussion thread: http://www.eurobrick...howtopic=102692
Wiseman_2 Posted November 24, 2014 Posted November 24, 2014 20. Log Loader Here's my entry for the contest, built using parts only from 8049. You can find the original entry thread here. Features: Pneumatically lifted two-stage claw crane Worm screw operate claw Crane can be rotated via the light on the cabin roof Two-stage steering, with both articulated and rack-and-pinion steering - by turning the exhaust stack, the rear body articulates, while at the same time the rack-and-pinion on the central axle also turns, resulting in 3 different angles on each axle Pendular suspension on the rear axle Photos: Here you can see the mutli-angle steering: The rear axle suspension: And a few more shots: More photos can be found here
Jeroen Ottens Posted November 26, 2014 Posted November 26, 2014 21. The Rare Red Grader Here is my entry for the [TC5] competition (based on the 8261 and 8048): + = The rare red grader It features: - Steering : HoG + steering in the cab - Pendular suspension on the front axle - Pendular suspension on the rear axle - Grader blade with the following articulation possibilities: - up/down (operated by pushing the rod forward or backward. It has a spring loaded knee-jack mechanism to keep it either up or down) - tilt around the vertical axis (operated by turning the wheel on the rod) - tilt around the horizontal axis (to make it follow the ground. Not a real life feature, but great for playability) - Ripper at the back (also with a spring loaded knee jack mechanism to keep it either up or down) - 2 cilinder fake engine driven by one of the wheels (not enough gears in the set to connect all wheels, but it is an easy mod ) And a picture from the leftover parts: More pictures from the functions: The ripper in the two positions: The blade in the up/down position: And finally the blade as seen from the top in the extreme positions + the middle: And finally here is the link to the discussion topic: http://www.eurobrick...howtopic=101556
petcz Posted November 26, 2014 Posted November 26, 2014 22. Pickup Truck with Dump Cargo Bed Hello everyone, this is my TC5 contest entry. It's a pickup truck with dump cargo bed. It is an alternative model for 9393 set. Model name: Pickup truck with dump cargo bed Features: HOG + steering wheel (working simultaneously) opening doors (simple "lock" - half of the axle 4 fits in the door case - a small force has to be applied) opening hood (simple "lock" - beam 2x4 is locked by cross block 1x3 - a small force has to be applied) opening cargo bed soft chassis to simulate independent suspension 2nd HOG for dumping cargo bed and/or rotating axle for attachable accessories (disable dumping by shifting gear 8 aside from the worm gear) large attachable winch special "parking feature" for overcrowded cities :-) Images: HOG + steering wheel, doors, hood and cargo bed opening Soft chassis Dumping cargo bed Attachable accessories And finally - smart parking :-) Link to the topic: [TC5] Pickup truck - 9393 alternative Leftover parts: pet
miguev Posted November 27, 2014 Posted November 27, 2014 23. Orange Buggy Alternative model built from sets 9392 Quad Bike and 42007 Moto Cross Bike. 296 parts, 300 grams, 32.5 studs long, 18.5 studs wide, 16 studs high. Features: independent front suspension live axle rear suspension RWD with fake V2 engine positive caster angle that helps steering return to center steering wheel openable bonnet fake gear and handbrake levels tall rear to make up for no rolling cage More photos and details in the discussion thread.
